Cell Phones Logo
Terry Wright Posted on May 17, 2019
How do I enter a n unlock code for network - Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
How to unlock motorzr z3
To Get the Motorola Rizr Z3 unlocked from network lock use the unlock code.....Buy the unlock code from the site Simpleunlocking.com and unlock it from network lock.Then use with any GSM Network Sim card......You can enter the Unlock code using the Free Unlocking instructions below:
Motorola RIZR Z3 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola RIZR Z3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola RIZR Z3 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola RIZR Z3 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola RIZR Z3 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
How can i Motorola MOTOROKR E6 unlock??
There are lot of ways to UNLOCK THE phone from NETWORK lock,But Unlock code is best in that,Specify the Network and Country it locked now?
Get the NETWORK unlock code from here
Mobileunlocksolutions.com and follow the instructions below and Unlock it step by step!!!!
Warning : Do not enter any wrong unlock codes on your Motorola E6 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola E6 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola E6 with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola E6 is locked to.
- "Tampert Alter"
- "Contact Service'
1helpful
Sim card locked on me
It's locked with Network? or locked with Security code?Security Lock means get the code from service provider and Reset it from Security lock of Sim!!! It locked to Network means specify the Network and Country it locked Now,then get the Network Unlock code for Pantech P7040 Link Phone at
Classicunlocking.com and Unlock it ,then use with any GHSM Network,To enter the code correct follow the Instructions below...
Pantech P7040 Link Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Pantech P7040 Link mobile phones. If you enter over a certain amount of wrong unlock codes on your Pantech P7040 Link mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Pantech P7040 Link with its ORIGINAL SIM card.
2. Type *#865625#.
3. A SIM Unlock Menu will appear, press OK.
4. Enter Unlock Code.
5. Re-enter Unlock Code.
6. Pantech P7040 Link will display Unlock Process Complete. Press OK.
7. Your Pantech P7040 Link is now unlocked.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the Pantech P7040 Link.
3helpful
2answers
Cannot unlock it
You can call the service provider and Unlock it..
How do I unlock a Motorola i680 phone
It's simple to Unlock Your Motorola I680 Model Phone from Network lock,You can use the subsidy code to unlock the Phone from Network Lock,You can get the code from here
Wickedunlock and Unlock it from Network Lock....You can follow the instructions below and Unlock it Step by step...
Motorola Brute i680 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Brute i680 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Brute i680 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Brute i680 with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Brute i680 is locked to.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Brute i680 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Unlock Network Pin For Motorola AT&T SKU C1681 IMEI 354656029204063
To unlock the Motorola C168I from the Network Lock ,get the Unlock code from here Onlinegsmunlock and Unlock it...
Motorola C168i Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola C168i mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola C168i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola C168i with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola C168i is locked to.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola C168i ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
I want to unlock my motorola defy can u send the unlock code
Sorry i don't have the Unlock code with me.Also no one provide the Unlock code for Your It's differ from Network to Network ,IMEI number and Country it locked Now...You can get the Unlock code at low cost from the website Named as Superunlockcodes.com and remove the Network Lock,If it asks for Security Unlock code means call the service provider and get it,Subsidy Code and Unlock code is Same,SPECIAL CODE is also same in Motorola Category,Motorola has Unlimited Unlocking tries,,Follow the Free unlocking instructions below :
Motorola DEFY Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola DEFY mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola DEFY mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola DEFY with a NOT ACCEPTED SIM Card,
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola DEFY is locked to.
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola DEFY ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Each Motorola DEFY mobile phone has an unique unlock code. You can buy the unique unlock code for your Motorola DEFY mobile phone using the form above.
7helpful
3answers
Unlock Nokia 1208
i want the unlocking code for my nokia 1208b /type RH-106/imei-011716000489011 please help me .
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
