Program to verizon box and samsung tv
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu
picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box:
on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
SOURCE: Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
SOURCE: verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
