Question about Food Mixers
I would like a copy of the 1222 RM DOD mixer manual and information as to where and how to obtain a power supply for it.
707A Gearbox is broken To BGR1 Can you give me service manual and drawing of Major A
You need to call the manufacturer on this, we do not have the information and can't supply parts.
Oct 11, 2012 | Kenwood Food Mixers
Kenwood Chef A901 Service Manual
Hi there I am trying to get hold of a copy of the service manual for the A701A mixer.
Would someone be able to send me a copy please....
email is simon@locom.co.uk
thank you to anyone that can help.
Jan 15, 2012 | Food Mixers
Only works speeds 6-8. Turns off when moving knob to lower speeds. Tightening two screws in the back of the mixer above the power cord changed the working range from 4-6. Any ideas?
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 26, 2011 | KitchenAid 32685 Mixer
My machine simply won't turn on .
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
Have a kitchenaid stand mixer Model # KP26N9XER the attachment hub is not turning correctly it only turns a liitle at a time with a thumping sound. Opened up looked at the gears and their are bits of metal...
Download the Service Manual :
It is not exactly for your model but you can learn a lot from it.
Open up your mixer. Get rid of all the grease. Replace the Worm Gear.
Use fresh Kitchenaid Food Grade Grease on all gears.
Caution: Do not use a screwdriver to pry out the Planetary Assembly.
Jun 20, 2011 | KitchenAid ProLine 600 Stand Mixer
K-tec Kitchen Champ 2000 manual information needed
Type into the search box above. Blendtec and it will return with nimerouus appliance sites. Some sites carry all sorts of brands and parts including manuals _Good Luck_ Ned
Oct 31, 2009 | Food Mixers
Instruction Manual for HOBART MIXER. How to get a copy
Hi Nelson. The next time you have a question please provide the Make, Model # and serial# of your mixer. This info will get you a faster answer to your question. It takes a little while to get used to this website. It took me a little while too.
Having said that, go to www.hobartservice.com, register and once you have been granted permission to access the website, you will be able to find all kinds of information regarding your mixer. If you have any trouble with the Hobart site, let me know, and I'll walk you through it. If you find this solution helpfull, please rate it. ricardok45 Good luck!
Jan 05, 2009 | Hobart A200 Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
Bruce Showalter
eyecam
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
