Acting wonky. scrolling in the wrong screen, even when clicked into the right one. I installed the drives yesterday, first time using on this computer.
I would uninstall the drivers, reboot, and let your OS install the mouse. Then try to re-install the new drivers that were released by Wacom yesterday available at the link I provided. (You probably got them there, I don't know)
If it goes 'wonky' again, uninstall the new drivers and use the older ones provided on the website or just let you OS install if it will.
https://www.wacom.com/en-sg/support/product-support/drivers
SOURCE: Wacom Wireless mouse ( install it without a CD what should i do)
I sassume you have the tablet on which the mouse sits, right? The name of the model should be written on the back of that. Just follow this link and choose your tablet model and away you go!
http://www.wacom.com/productsupport/select.cfm
SOURCE: G9 Laser Mouse Scrolling Problem
thx for helping dude, logitechexpert my ***...
now check that...i was so pissed because of such stupid advice that i hit my mouse on the corner of my desk...yep i really did.
...and then it worked! it SCROLLS!
my theory: the logitech has a quite complicated mechanical clockwork-like gear switch for their scrollwheel. they are so proud of it, that they even have pictures of it on the box when you buy a g9. well, i guess when you make things more complicated they arent that reliable anymore...like the gear switch at your bycicle which gets messed up sometimes, because its small mechanical parts just get stucked.
so my mechanical solution: turn your g9 around hold it and knock three times(not too soft: imagine the money you paid for this mouse and release your anger) just around the area where the mechanism is located...i had exactly the same problems like you and now it works perfectly!
...i guess i dont need to buy batteries.
SOURCE: My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
SOURCE: My wacom tablet pen is acting like a mouse...
go to the pen tablet program folder and start up pen tablet properties and there should be an option to use the pen as a pen or as a mouse. if this does not help then the pen may have some problems.
SOURCE: My computer suddenly won't recognize
Make sure driver is installed and there is not any ? mark or yellow ! mark in device manager.
Reinstall your tablet driver then check.
Uninstall all usb driver from computer.
Connect your tablet to computer then when you power up the computer press F8 key then enter in safe mode.
Make sure usb cable is works fine if you connect your tablet to computer with usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
