SOURCE: yahoo not responding
Scan your sytem with antivirus.
http://www.avast.com/eng/download-avast-home.html
SOURCE: problem with accessing and sending mail from yahoo account
Re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
1.
Click Start, and then click Run.
2.
In the Open box, type cmd , and then click OK.
3.
At the command prompt, type the following lines and press ENTER after each line:
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 cryptdlg.dll
4.
Click OK when you receive the message that DllRegisterServer in FileName succeeded.
5.
Type exit .
Hello laurenloscia
alot of the times, just going into internet options and setting everything to default, and clearing the cookies and files works about 50% of the time.
This is possibly a yahoo issue. If you use yahoo thru ATT, you can call ATT for support and they will escalate any valid issues to yahoo for you.
Their phone number is 1-877-722-3755
ask for tech support at the prompt
they can remote on your computer to see if it is a java issue or whatever
if they can replicate it on their computer also, they will create a yahoo trouble ticket and give you thier member service number. Yahoo resolves 85% of these within 48 hrs.
If they cant replicate it, then they will consider it a pc issue and refer you to connect tech or to best buy's geek squad.
Personally, I would also try sending emails in safemode, If you can do it in safemode, and not in reg mode, it is definately PC related.
To get to safemode, turn your computer off and when you turn it back on, tap the F8 button until you get an advanced screen. Pick safemode with networking with the arrow keys. Log in, click yes when it tells you you're running in safemode, and then when your on your desktop, which will look alot differnt, black background with big icons, click on internet explorer and go to mail.yahoo.com and see if it works now, if it does, like i said, its pc related. If it still cant, call ATT's support if you have thier DSL or U-Verse
spin
spin
SOURCE: saya lupa password email dan
i'm forget my pasword email.. my email [email protected] help me
Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
