Serial Port
Signal Names
Header
Comments
Serial1
/TxD1, /RxD1, XCV1+, XCV1-
HCS12 Comm Header
Standard baud rates up to 115.2 Kbaud. Jumper selectable RS232 or RS485. Jumper selectable termination options. All signals are also available on the Docking Panel.
Serial2
/TxD2, /RxD2, XCV2+, XCV2-
HCS12 Comm Header
Standard baud rates up to 115.2 Kbaud. Jumper selectable RS232 or RS485. Jumper selectable termination options. The RS485 signals are not available on the Docking Panel.
IIC
SDA, SCL
Analog Field Header
2-wire multi-drop bus, up to 100 Kbaud. Each device must have unique numeric address.
SPI0
MOSI, MISO, SCK
Wildcard Bus Header
3-wire multi-drop bus, up to 10 MBaud if SPI bus master, up to 5 MBaud if SPI slave. Each device must have unique hardware chip select signal.
SPI1, SPI2
MOSI1, MISO1, SCK1, /SS1, MOSI2, MISO2, SCK1, /SS2
SPI Header
Used for inter-processor (IP) communications on multi-processor systems such as the PDQScreen. Can be used to communicate with other peripheral devices if multi-processing is not required.
RS232 and RS485 communications
The PDQ Single Board Computer (SBC) has two asynchronous serial communications ports named Serial1 and Serial2. Each serial port can be configured for the RS232 or RS485 protocol, and runs at standard baud rates up to 115,200 bits per second. The default baud rate after a factory cleanup is 115200 baud. The Serial ports are implemented by the dual on-chip hardware UARTs (Universal Asynchronous Receiver/Transmitters) on the Freescale 9S12(HCS12) microcontroller.
Each UART (sometimes referred to as a "USART") controls the serial-to-parallel and parallel-to-serial conversion and performs all of the timing functions necessary for one asynchronous serial communications link. They translate the bit-by-bit data on the serial cable into bytes of data that can be interpreted by the operating system or by your application program. The communications is asynchronous because no synchronizing clock signal is transmitted along with the data. Rather, the UART deduces the correct time to sample the incoming signal based on the start and stop bits in the signal itself.
The Serial1 and Serial2 ports have identical communications capabilities, although more of the Serial1 signals (both RS232 and RS485) are made available on the Docking Panels headers and connectors. After a factory cleanup, Serial1 is the default serial port for program development and downloading. In a finished instrument, either or both channels can be used to communicate with other serial devices, or with other computers and/or terminals using RS232 or RS485. Having a second serial port is also handy for system debugging. Since both channels can operate simultaneously and independently, serial debugging can be performed while the application program is
SOURCE: laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
SOURCE: DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
SOURCE: Siemens SpeedStream 4100 Network Router - cannot enter
click start then run, then type cmd click ok
This should give you a black cmd window. In the window type ping 192.168.1.1 and you should see a few messages saying reply from.......
If you get this try opening internet explorer and type http://192.168.1.1
Cheers
Dave
SOURCE: DNS
If the Windows 2003 server is utilized as the DNS server, then yes it should be set to 192.168.1.5. You need to get into the Linksys router via http://192.168.1.1 and under DNS of DHCP if it is set to .1.1. You should be able to change it to .1.5.
