Question about In Office Equipment & Supplies
Hi, Where can I buy a typewriter in Arabic Thanks
How to change arabic to english
The problem is not only the character set but the writing direction. Arabic pronts from right to left. So you should check your User's manual, what to do about. If you don't have it download from
http://www.manualslib.com/manual/219342/Brother-Ce-400.html
The problem might be is the typewriter is differet design, specific for arabic. I Actually could't find a mode to change the printing direction.
Mar 23, 2015 | Brother EM-430 Typewriter
How i can shift from english to arabic
New Printwheel and keytops, some you can control in set up .
Sep 11, 2013 | Nakajima AE-800 Typewriter
How i can shift to arabic
You have to buy an Arabic printwheel and install it.
To insert the daisywheel:
1. Open the top cover.
2. Pull the lever toward you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear" on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its original position to lock the cassette daisy wheel into place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press and hold the CODE key. While holding CODE press the Q key, this will move the carrier to the previous position.
Sep 11, 2013 | Brother SX-4000 Typewriter
Change from Arabic to English?
Go to NADIST.COM, click on current models tou will find a manual there.
DickyO
Jan 19, 2011 | Nakajima AX-150 Typewriter
Can you suggest a model for ARABIC & English letter Typewriter ?
It is unlikely you will get a typewriter with 2 languages....think of the problem of labeling the keys, as well as limited memory in a typwriter to contain both languages. Most typewriters are available in North America as either ENGLISH, FRENCH, or SPANISH. These being considered the most common languages.
Feb 08, 2010 | Olympia Office Equipment & Supplies
Olympia typewriter changing Language
It is "unlikely" that the machine contains both English and Arabic languages...not enough room in the memory plus keytops would be different for the 2 languages.
Apr 30, 2009 | Olympia Office Equipment & Supplies
21 people viewed this question
Top In Office Equipment & Supplies Experts
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
