SOURCE: i hookled up a crunch
You Conected the power cables up wrong and the amp is protacting its self from being fried.Make sure positive and negative and remote turn on is correct
SOURCE: I have a V 150 SE crunch amp. i have a red light
This more than likely means that you have a blown fuse. Go to an electronic store and replace the fuses. Make sure you get the exact same sizes and types that you had before.
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
SOURCE: crunch 1500 went into protect
Hi ,
If you have a knowledge in disoldering and
soldering technique, I would advice you to pull-out this part and then try the
unit. If the "Amp Grd" error code is gone then you must replaced this
IC with a new one to back your unit in normal operation again.
"Protect" is an error code for short and overload. Once the power applied to the unit and shorts sensed by the processor, the unit will
automatically turned to "protect" to avoid further damaged to other
parts. Most shorts is in the supply voltage (B+, Vcc) line and most common
caused is the sound output IC (mounted in heat sink). This part is responsible
for amplifying the audio from the pre-amplifier stage and will feed to your
speakers.
Before that, try to isolate first the speakers, if you have a shorted one, same symptoms will be encounter. Disconnect all the speakers from the unit and turned it on naked. If the symptoms is gone, then check for shorted speakers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Hi ,
speakers.
Hope I helped you.
Have a nice day!
Crunch amp was working just fine. Then one day it just shut off.. now when we try and turn it on.. it immediately turns off
