There will be a small hole on the side of the phone.
trick is to cut sharp end off a pin and push it into hole to catch the mechanism/ hole to release the tray. Then slide the nano sized sim in the tray cassette back in phone
If you have a small paper clip that will fit in the hole it’s easier to pop the tray out using that. If the hole is to small for a small paper clip, cut the tip off a large safety pin and use that. Only apply enough pressure to release the catch on the tray.
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
SOURCE: MY NOKIA 6300 IS SAYING 'NO SIM CARD INSERTED', BUT THE SIM CARD IS INSERTED. WHAT CAN I DO?
no problem.. jus remove your sim card and reinsert it. .sometime it may happen like this..
Put two layers of paper between SIM card and SIM holder to make it a tight hold.It solves your problem.
SOURCE: on my screen it says insert sim,or view demo of
Is this a new phone? If so check that you've inserted the SIM correctly and it's not SIMlocked to another network
If it's worked before remove the SIM and GENTLY clean the contacts on the phone and the SIM with a pencil eraser.
SOURCE: ive got a d2712 mobicel
ive got a mobicel d2710 and when i forgot my unlock code for the settings menu.pls help
