SOURCE: V262 constantly beeps "low battery" alert
I have v262, the problem sometimes is the contacts where the charger and phone gold connections meet. carefully inspect where they meet when charging, and remove any debris from them with help of a small pin or a dry toothbrush, but gently especially with the charger, because the plastic sometimes breaks. No big problem while cleaning, but make sure
there is no debris in contacts.
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
SOURCE: black jack 2 wont charge or turn on
take out the SIM and micro sd and turn on the phone. then shut it off again, replace sim and micro sd then turn back on. DONE! **works on samsung jack too!!!
SOURCE: My Casio Gw-300 G- Shock
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
SOURCE: How come my battery wont charge on my brand new
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
