Insert the disc into your disc drive, and locate the game in your C:Drive then move the game to you respective hard drive and launch the executable file. The game should automaticly download from there.
HI, you cannot install the game with incomplete discs. It is required. Try searching and downloading files of disc 1.Ex. Sims disc 1 download.In the installation it will prompt you to insert the next disc, then you can use your discs
what disc did you use to burn the game onto? for Playstation you will have to burn the game on a DVD disc +R for it to work,
if you copied the game from a disc and burnt it like burning a normal disc it may cause errors as well,
download Magic Disc http://download.cnet.com/MagicDisc/3000-7970_4-10383679.html creat an ISO copy from the game disc that you borrowed, once the ICO is created from magic disc, use magic disc as well to mount the ISO file you created thenyou can use Nero or Alchohol burning software, Magic disc will create a virtual disco n your system mount the ISo you created on the virtual drive, then open your burning tool Nero/Alchohol then select copy DVD select the virtual Drive then select the path where the game will be burnt on make sure you use a DVD +R disc ^_^ and that the file is not more than 4.7GB if it is then you will need to use a dual layer DVD + R disc
go to ps3 store and look under games then look under add-ons, then look under add-ons for disc games or if you downloaded it look under add-ons for downloaded game, goodluck, E
I believe that game has 3-4 discs actually. Perhaps they're in another case or something?
If not, he can try downloading the game by going to http://www.utorrent.com and installing utorrent, then go to http://www.btjunkie.org and search for the game. If you find it, click on the link for it and open the torrent file in uTorrent and it will start downloading the game. It will download to your "My Documents > Downloads" folder by default.
Hi Natty579,
The problem is that you need a crack for the game, it a common problem with downloaded games (if you purchased the game then it's a game copy, not an original game). The problem solves when you crack the executable, it's just a download a file and replacing it in your game folder.
