Televison & Video Logo
R
Robert Powell Posted on May 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I select ANT/cable in on my TC-50PU54. It shows not used
b1jqxk44
Level 2:
Habit-Forming:
New Friend:
  • Expert 157 Answers
  • Posted on May 18, 2019
b1jqxk44
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
157
Questions
7
Helped
36397
Points
395
1 Related Answer
Anonymous
  • 879 Answers
  • Posted on Dec 01, 2012
SOURCE: model number tc-50pu54 panasonic plasma tv brightness fluctuates when live tv basketball game is on
Check and replace its Z-sustain board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Lightning hit and our Panasonic Viera displayed, No signal. TV won't show networks, but Netflix and internet is still working. I'm not sure what part is messed up. The main board?
Ckexk that your aerial installation is not damaged, it is possible the cable is damaged. If you try another tvvon it an it does not work there is your fault. It may be that the tuner section has gone but I would definitely try the aerial as the first step to a diagnisis in this case
GOOD LUCK
1helpful
Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
2answers
Our Panasonic Viera TC-32LX700 displays "Channel not found". We have unplugged it and gone through the initial set up all over again. It is connected to am antenna, not cable. After the display, the screen...
Try relocating the location of your antenna or changing the direction it is pointed. Once this is changed, select PROGRAM CHANNEL from the SETUP menu and set ANT IN to Antenna before selecting Auto to start the programming process.
Panasonic tc-50Pu54 dinostic code...
test the ac power 2) main power ac/switch 3)fuse 15aa,and replacemente
see the diagram attached. God bless you
Model number tc-50pu54 panasonic plasma tv brightness fluctuates when live tv basketball game is on
Scion tC won't start, ant-theft system light turned blue
are you using the key that came with the car?
key has to be the one that came with car or you have the one that only opens the doors
2answers
I have cable and when i plug it into my tv i only
The tv will only process cable channels when set to 'ant cable' . After the scan, you should be able to view all channels provided on the frequency.
If you want more cable #'s, you will have to pay for those or get a cable box. If you don't find your local channels in the lineup, you will have to use a switcher, or hassle with unplugging and plugging the antenna. This is true for ATSC broadcasts. Please give feedback if this helps. Or tell me more.
How to get from standard TV to Cable TV?
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
I cannot record a show onto a blank vhs tape in my vcr??
Initially, pls verify that the coaxial cable is connected to the ANT/Cable/RF IN of the VCR. Thereafter the built-in tuner of the VCR would be used to select the desired channel to be recorded. The VCR in turn maybe connected two (2) ways to the TV:
  • Audio/Video using yellow, red & white RCA cables/connectors using AV1 or Video1;
  • RF patch cord from RF OUT of VCR to ANT/Cable/RF IN of TV using either Channels 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
