My system says debug code will not do nothing else ls
Debug LED code AA - computer errors and tries to restore every boot and never completes and shutsdoiwn
What is the make and model of the motherboard? The LED code means nothing without this information.
Aug 04, 2013 | Computers & Internet
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • Oct 25, 2011 | Microsoft Windows XP Professional
    I have p0430, nothing else? 2004 LS V6. What is it?
    This code that camenupnpointsnto a problem with your cadilatic converter. Take it to a local shop you trust and for free they can put it on there machine to confirm this and give more details of solution and cost. Please keep me informed, let me know if this helped by the 4 thumbs up clicked on. Thanks mike
    Jun 18, 2011 | 2004 Lincoln LS
    Microsoft visula c ++ runtime error how to fix it
    I assume here that you are writing an app in VC++. If the problem is that the code runs in Debug mode, but crashes in Release mode, the usual reason is a pointer overflow bug. This is commonly when a pointer is not initialized or a buffer is too small for the data written to it.
    In Debug mode all variables are surrounded by guard bytes (allowing the app to run...), but these are removed in Release mode. The guard bytes are the main reason that Debug builds are about 2x the size of a Release build.
    Set Debug mode, and hit F5 to run the app. It will probably stop at the source of the error. If not, then you'll need to put in some MessageBoxes in various places to locate the code region that has the bug.
    sd www.pixcl.com
    Jun 09, 2011 | Microsoft Computers & Internet
    See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
    Not sure whether this is a Q.
    To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
    In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
    It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
    How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
    Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
    The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
    May 29, 2010 | Dell Studio XPS 16 Notebook
    DeBug appears whenever
    what IE are you using?
    the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
    Mar 27, 2009 | Microsoft Windows 2000 for PC
    Runtime errors
    Solution:
    i) usually whenever there is virus, spyware, ... in your system some of the .dll will be lost or will lead to curruption or partial currption(some data or all the data in the .dll will be lost)
    ii) as such some .dll files are heart or important to run system, some .dll files play mere role.
    iii) when such .dll files are lost the program using these .dll files cannot locate or find their .dll files in such you get errors message as u said......
    iv) as u debuging is not possible in the normal way until unless you have some debugging program or software such as "Visual Studio 2005" or Visual BASIC TOOLS....
    v) due to loss of some important .dll files your system might shutdown frequently..... but you are fortunate that you are getting error message....and these .dll play mere role....
    vi) i would suggest to install some best rated antivirus, spyware( Bit Defender -rated top, AVG, Norton....) after perform full system scan try reinstall your OS or format your system or load OS Freshly....
    Thanking you
    M. Sridhar
    Dec 27, 2008 | Computers & Internet
    2003 Lincoln LS code P1406
    Hi........
    On your LS.
    The CODE P1406,
    IS Mean: Differential Pressure Feedback egr. problem.
    Ok.. Is just the definition for your code.
    The DPFEGR.. is a Little BOX. Black Colour.
    Is Normally connected to the EGR tube coming from the EXUAST MANIFOLD. with 2 small hoses.
    Inspect the Hoses for broken, burn or stuck with carbon.
    if you DON'T found nothing wrong.
    Replace the DPFEGR. You van get from DEALER.
    DON'T get from autoparts because they only offer one
    UNIVERSAL. and most cases don't work right.
    Ok.. I hope this help to try to fix your car.
    Thank you for use fixya..
    Aug 09, 2008 | 2003 Lincoln LS
    Open Questions:
    Computers & Internet Logo
    14 people viewed this question
    Ekse
    Marvin
    Marvin
