Computers & Internet Logo
Ricky Posted on May 16, 2019
My system says debug code what is in that and how do I fix it
2answers
What is the unlocking code for Samsung mobile IMEI number is 351**********61/01
I suggest you can approach Prounlocking.com and specify the country,locked network of Samsung .Based on the availability you can get the permanent unlock service along with free instructions.
How to turn on usb debugging by using a PC
Im finding no way around it. To open the service menu a code typically needs to be inputted into your dialpad. Sorry, sounds like getting the screen fixed may be your only way.
Jit debugger error
jrotten65,
This error only pertains to Microsoft Visual Studio. Depending on which version of the software you are using, follow the links below.
Try updating to the newest release of Visual Studio
http://www.microsoft.com/express/
or use the Debugging Tools for Windows as an alternative
http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx
The Registry key HKLM\SOFTWARE\Microsoft\.NETFramework\DbgJITDebugLaunchSetting is set to 0x00000010 when JIT debugging is enabled.
I hope this helps.
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • 0helpful
    Microsoft visula c ++ runtime error how to fix it
    I assume here that you are writing an app in VC++. If the problem is that the code runs in Debug mode, but crashes in Release mode, the usual reason is a pointer overflow bug. This is commonly when a pointer is not initialized or a buffer is too small for the data written to it.
    In Debug mode all variables are surrounded by guard bytes (allowing the app to run...), but these are removed in Release mode. The guard bytes are the main reason that Debug builds are about 2x the size of a Release build.
    Set Debug mode, and hit F5 to run the app. It will probably stop at the source of the error. If not, then you'll need to put in some MessageBoxes in various places to locate the code region that has the bug.
    sd www.pixcl.com
    1helpful
    See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
    Not sure whether this is a Q.
    To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
    In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
    It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
    How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
    Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
    The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
    19helpful
    4answers
    Samsung s5230 security code reset
    hi i have samsung s5230 and it has got security code on the reset settings
    1helpful
    2answers
    Unlocking code for SAMSUNG SGH-B270
    kum pot obtine defreez code pt samsung b270i ?
    2answers
    Help me
    this the code for your problem. by the way this for vb6.0
    Sub CountCharacters(Text As String)
    Dim iVowel As Integer
    Dim iCons As Integer
    Dim iNum As Integer
    Dim iSpace As Integer
    Dim iOther As Integer
    Dim cnt As Integer
    Dim sChar As String
    For cnt = 1 To Len(Text)
    sChar = LCase(Mid(Text, cnt, 1))
    Select Case sChar
    Case "a", "e", "i", "o", "u" ' And sometimes "y"?
    ' Vowel
    iVowel = iVowel + 1
    Case "a" To "z"
    ' Includes the first case, but VB matches the first case and stops
    iCons = iCons + 1
    Case "0" To "9"
    ' Numbers
    iNum = iNum + 1
    Case " ", vbTab, vbLf
    ' Space characters
    ' Not including vbCr as this will likely be dealing with Windows text
    ' and I only want to match one character for a newline
    iSpace = iSpace + 1
    Case Else
    If sChar <> vbCr Then iOther = iOther + 1
    End Select
    Next cnt
    Debug.Print "Text: " & Text
    Debug.Print "Vowels: " & CStr(iVowel)
    Debug.Print "Consonants: " & CStr(iCons)
    Debug.Print "Numbers: " & CStr(iNum)
    Debug.Print "Space characters: " & CStr(iSpace)
    Debug.Print "Other: " & CStr(iOther)
    End Sub
    3answers
    Runtime error pop-up
    Solution:
    1. install Internet explorer version 6 or 7
    2. install service pack 4 if it is Windows 200,
    3 install service pack 2 if it is Windows xp
    4.install the windows updates up to date
    definetly will fix the problem
    Grand Canyon Tech
    Grand Canyon Tech
