Hello Elvira, comment that Vizio TV model you have
Did you try to turn it on from the TV itself?
Also check the outlet, which is in good working order, disconnect the TV and connect a lamp to check that it works
If with all this you can not make it turn on, I suggest you contact the VIZIO helpdesk
I pass the link where it tells you how to contact them
I hope you can solve the problem
Greetings Franco Dosil
Hola Elvira, comenta que modelo de TV Vizio tienes
Intentaste encenderlo desde el propio televisor?
Tambi?n revisa el toma corriente, que se encuentre en buen funcionamiento, desconecta el TV y conecta una lampara para comprobar que funcione
Si con todo esto no logras hacerlo prender, te sugiero que te comuniques con el servicio de asistencia de VIZIO
Te paso el link donde te indica como contactarte con ellos
Espero que puedas resolver el problema
Saludos Franco Dosil
If you are in the United States
Si estas en Estados Unidos
https://support.vizio.com/s/contact-us
If you are in Mexico
Si estas en Mexico
https://support.vizio.com/s/?language=es_MX
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine.I used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
