Question about Electronics - Others
How to charge PowerDisk USB Flash Disk watch
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Tip
How to flash your disk [USB]
How To Flash Your Flash Disk
[ USB ] Universal Serial Bus
  • First : Open Your USB Disk ( Like The picture )
  • There are two black Ships , marked with Three codes
  • A code has 6 Numbers , A VID Code and A Pid COde
  • copy all the codes to a bloc-note
  • open this site : http://www.flashboot.ru/iflash.html
  • Write The First Code Second Code and The Third code (Like The Picture)
1) Click Enter
2) The Site Give's You A lot Of Information
3) Choose You usb Disk Data (See The Picture)
4) Download The Flash Application
5) Connect Your usb Disk On The Computer
6) Open The Flash Application
7) It give's a button written on it : << Flash /or/ Preformat >>
8) Push The Button , Wait For A minute
9) Your usb disk Will Be Flashed ;)
Fix-shad0w
Please Rate .
on Jul 07, 2010 | Computers & Internet
The disk is shot. i will not work , and i cant format it. i have had this for about 3months and now this.
static charges fry these very easily try to be careful also plugging it into front of the computer could be riskier than the back
Mar 02, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I NEED HELP GETTING ON TO MY MAXWELL 4GB FLASH DRIVE BECAUSE I DONT KNOW HOW TO OPEN IT AND I NEVER USED ONE BEFORE
1. you need to format your new usb flash disk
2. just insert it to a usb port and it will automatically open the the flash disk or you can go to my computer it will display there the flash disk drive
Nov 13, 2010 | Electronics - Others
Bought a maxell 8gb usb flash drive. When I try to use it it comes up with message "insert disk into drive j". Any suggestions?
By trying to use it I take that to mean you go to My Computer and select the drive you believe it to be.
Try going to My Computer with the flash drive unplugged and then plug it in while watching My Computer for a new drive letter to appear. That will be the one to use.
If you select the wrong one you will get the message you are experiencing.
May 19, 2010 | Electronics - Others
PS3 USB ports won't work
First of all you can't watch movies off a pendrive anyways=p and as to your controller not charging try a different chord or a new paddle
May 27, 2009 | Sony Playstation 3 (PS3) Console
PQI 1GB Intelligent Stick USB 2.0 Flash Drive
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Dec 03, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Electronics - Others Logo
26 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
