Question about Alcatel Cell Phones
Root alcatel pop 4 plus. My phone will not boot into bootloader mode. If just restarts
SOURCE:
  • 117 Answers
SOURCE: phone only on bootloader
bootloader is the programing mode for when motorola loads the operating system. Typically this will happen when a bad flash code is used. You can try and remove the battery while the phone is turned on and hope it reloads the OS. Otherwise talk to your carrier about warranty stuff.
Posted on Jan 20, 2008
teddc
  • 115 Answers
SOURCE: need bootloader 06.A3, Err:a5,69,35,00,2E
This is an internal software error. If your phone is less than 1 year old you can get it replaced at no charge from your provider. If it is over 1 year old you would need to use your insurance if you have that option. Point is, t he phone will need to be replaced.
Posted on Apr 21, 2009
himanshu007
  • 218 Answers
SOURCE: please guide meto restart the phone how to reboot "bootloader version"
u cant do it by ur own, u need to go to motorola service center to get it a software update
Posted on Jun 03, 2009
issikiki
  • 563 Answers
SOURCE: I messed up my HTC
hello.
It seems like you have to take it back to the company/store to get it recover from you, as upgrading and downgrading it can cause the system to be interrupted or damaged.Since its ignoring an update, I'll suggest you take it to be recovered as it will not go to recovery mode.
Posted on Aug 21, 2010
  • 378 Answers
SOURCE: The MSM 422 Access Point
I think you need to get the latest firmware and load it. You should be able to stop the bootup as soon as you power it on.
HP Support can be reached at 1-866-my-procurve. Their support group should be able to help out.
Posted on Apr 25, 2011
How to unlock bootlocker on LG K20 without pc
You can't, but this guy says you can.
https://www.youtube.com/watch?v=LzXoRe9-O-U
How To Unlock Bootloader On LG K20 Plus (T-Mobile / Metro PCs)
https://www.getdroidtips.com/unlock-bootloader-lg-k20-plus/
Jun 11, 2017 - Now you can unlock your bootloader on LG K20 Plus (T-Mobile / Metro PCs) officially. Today we will guide you on How to Unlock Bootloader on LG K20 Plus (T-Mobile / Metro PCs) Smartphones. So before installing TWRP, LG K20 Plus (T-Mobile / Metro PCs) smartphones should be unlocked. So here is ...
How to Unlock the Bootloader on LG K20 Plus (T-Mobile/MetroPCS)
www.thedroidway.com/unlock-bootloader-on-lg-k20-plus/ Nov 9, 2017 - If you want to root or flash a custom recovery, the first step is to unlock the bootloader on your LG K20 Plus. Once the bootloader is unlocked, you have the freedom to flash a custom recovery like TWRP, and then custom zips & mods, which is otherwise not possible with a locked bootloader. Fortunately ...
Making alterations to the BIOS/Boot area of the phone often results in a broken phone. Read the disclaimer, you may end up with a brick.
How to unlock bootloader of any Android device without pc
how to unlock bootlocker on lg k20 without computer Google Search
Jan 23, 2018 | LG Cell Phones
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
What's your question? my M XT907 is locked how do for dislocked him?
Please described your problem a bit, if you want to unlock the Boot-loader of Motorola xt907 RAZR or you want to unlock the SIM.
Here I am giving you both the solution what I found on the Internet:
1. boot-loader unlock SIM Unlock Verizon Wireless Motorola Droid Razr For GSM Use
2. Root and Unlock Root and Unlock Bootloader of Droid Razr XT907 On 4 4 2 KitKat
Oct 03, 2015 | Cell Phones
Phone keeps restarting
you have to reflash it or to fix the bootloader
Feb 15, 2014 | Alcatel Cell Phones
Unlock
I should first point out that there are other options to unlocking yourself, since this option is a bit more involved and can seriously mess up your phone:
1) You can get the unlock code from your provider for free if they are prepared to give it to you. If they are then that is the safest and best option.
2) For $25, you can use TheMotoGuide's unlocking solution which is instant and guaranteed.
That being said, here's directions on how to unlock the phone yourself:
*You need to downgrade your boot loader to 7.D0, be aware that this can be risky.
* You may find afterwards that when starting in bootloader you have only a blackscreen, so long as the phone works ok and you can connect in bootloader that is nothing to worry about
* Ensure your phone is fully charged before starting. I recommend before beginning you first make a backup of your phone as described in the back it up section. Especially the PDS back up. This assumes all necessary drivers are already installed.
1) Start in bootloader mode (hold # and * while powering on)
2) Identify your current bootloader (e.g. 8.26 or 7.E0)
3) If you already have bootloader 7.D0 skip to step 6
4) Download bl_826-828_to_07d0_for_V3_by_Archy.V2
5) Flash with this file using RSD Lite (described at the Flashing and Flexing section)
6) Download and extract the MOTO UNLOCKER SOFTWARE
7) Start in bootloader mode (hold # and * while powering on). In bootloader mode after the downgrade it is not unusual for the phone to show a blank black screen with no info, don't worry, though, it is still in bootloader mode!
8) Open up Moto Unlocker and connect you phone
9) Run Moto Unlocker click connect and yes! Once finished it will look like this:
Congratulations, your Motorola Razr V3 is now unlocked
Jun 13, 2010 | Motorola Mobility RAZR V3
Please guide meto restart the phone how to reboot "bootloader version"
Jun 03, 2009 | Cell Phones
Upgrade Ubuntu Error
-While booting your grub bootloader, press "e", enter the edit mode.
-Press "e" on the first line.
-(hd0,0) Change the last 0 to a 2, so it reads: (hd0,2).
-Press ‘b’ to boot.
Good luck.
Jul 29, 2008 | Canonical Ltd. Ubuntu
Bad battery or bad phone?
Looks like your phone is in 'Bootloader' mode, that's why it shows your bootloader info. Take your battery off for about 5-10 mins, and restart your phone.
Jun 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Alcatel Cell Phones Experts
D. E. Hev
Tony Pez
Level 1 Expert
Mark Snell
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
