Question about Dehumidifiers
I have Idylis dehumidifier model#0526051 and when the dehumidifier is running the air coming out of the dehumidifier is quite warm. is this normal or is there an issue with my unit. thanks. joan
2 Suggested Answers
SOURCE:
  • 54189 Answers
SOURCE: Looking for the drain tubing and the plastic brain connector for a Idylis dehumidifier model #0526051. Can you help??
Fixya does not sell Idylis dehumidifier parts.
Posted on Aug 05, 2018
I have an Idylis dehumidifer with pump model 0526051 does it need a hose in the water tank to pick up the water in the tank?
Normally dehumidifiers collect the water that they have pulled from the air in the tank. Therfore no hose is required. You just have to empty the tank when full. Most models have a float switch which shuts off the machine when the tank is full. Hoses to get rid of water are normally only fitted on industrial machines.
Sep 11, 2018 | Dehumidifiers
Idylis 0526051 dehumidifier - ice build-up. After 7 months of use this started to make a laboured noise that was audible the floor above. I switched the unit off and noticed what appeared to be a "check...
Dust and dirt that causes loss of airflow through the coils is the most likely cause. The only other reason would be a low refrigerant charge to the compressor.
Dec 26, 2014 | Dehumidifiers
Runs but no longer collects water
In the price range, most of the comparable united are the same under the skin. I like whirlpool since replacement parts are widely available.
before you condemn the unit, check three airflow and the temperatures of the suction and discharge tubes a few inches from the compressor. If the discharge is hot and the suction is cold, the circuit is probably still whole.
Nov 30, 2014 | DeLonghi DE400P Dehumidifier
IDYLIS 052605 dehumidifier will not shut off when the desired humidity level is reached The machine just keeps running.
well does the unit continue to make water in bucket, the reason i ask is that some units have an air circ fan that runs all the time reguardless of setting this is how its designed
Oct 05, 2014 | Dehumidifiers
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
Dehumidifiers Logo
73 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
