SOURCE: Bernina 1008 sewing machine making
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
SOURCE: needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
SOURCE: Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
SOURCE: I have a Bernina 950 Industrial bottom stitch loose and pulls out
tighten top thread tension.
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
