SOURCE: How to change microwave bulb
If
there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: safety switch keesp coming on ! Morphy richards
The safety switch is normally a motion sensor , it should only come on when there is no motion and the iron is face down. Try shaking it up a bit as it has a moving ball inside that detects the motion. Failing that it would need a motion sensor replacement or calibration. Regards PSP
SOURCE: Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
SOURCE: morphy richards steam generator iron
Try bottled spring water... many times tap water will not steam right...
heatman101
SOURCE: MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
