Question about Electronics - Others
"e-out" What does this error message mean?
KEB Combivert 07.F5.C1B-3B0A
5 Suggested Answers
SOURCE:
allinallelec
  • 407 Answers
SOURCE: please i need a programming manual for KEB COMBIVERT F4 INVERTER
For some time internal battery & main battery line disconnect you.so automatic reset.
Posted on May 28, 2012
  • 120 Answers
SOURCE: F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Posted on Apr 01, 2014
  • 120 Answers
SOURCE: Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
  • 120 Answers
SOURCE: We have KEB Combivert F5 drive Matno. 15F5C1E-350A Version. drive is installed in machine and is not working right now.i want to run the drive in Manual mode to test it.
if the display says LS, it means you are missing the speed and direction command. Via the keypad, provide the direction and then the speed.
Posted on Mar 07, 2015
What is cable breakage at the resolver or incremental encoder
It means that the signals between the inverter and feedback device are being lost. This is due to a cable breakage, defective encoder/resolver, or loose connection, possible defective feedback card.
Feb 24, 2014 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 help
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
on Nov 27, 2013 | Inverter KEB COMBIVERT F5
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
My keb combivert f5 ser- no. 02292642/0450840 art-no.12.f5.b1d-3aoa is faulty due to operational error, i want to reprogram it so that it can function very well so please l need a programming manual and...
Go to: http://www.kebamerica.com/en/service-downloads/downloads.html
SelectManuals
Frequency inverter
Language - ALL
The click on search.
You will want to look at the manuals under: Frequency Inverters > COMBIVERT F5 > Control Circuits > Basic (51)
Sep 01, 2013 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 parameter
The manual that came with the inverter has instructions on how to go from mode to mode.
If you do not have the manual, these can be downloaded from the KEB web site.
Jul 21, 2013 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
22 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
