The only hoop that I know is compatible with the Creative 7570 is the Creative Deluxe Hoop, part number 412944502. See the compatible accessories, hoops here: http://www.pfaff.com/en-US/Accessories#.99.62 . I've found this hoop in stock here: https://www.performancesewing.com/partsdatabase/embroidery-hoops/pfaff-deluxe-hoop-360x200mm.htm and here: https://www.peddlersway.com/shop/c/p/Creative-Deluxe-Hoop-360x200-x1994405.htm .
I hope this helps.
SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
SOURCE: 7570 sewing machine
Go to ebay and buy for about $60. Better price than Pfaff and machine 7570 is a very old model.
SOURCE: Can't connect Singer XL1000 Embroidery Hoop
well P it sounds like your hoop might be bent or at least the pins that go into the arm see if you can bend them out a bit also does this happien with all sizes of hoops?
Also for the Guest make sure that your needle isn't bent better yet just change the needle also take your bobbin out and flip it the other way and see if it still comes through hope this helps you guys
SOURCE: I bought a used 7570 and it came with 3 hoops. I
In Embird you can select the sizes for the hoops you have. In the editor under options you can select the hoops for your machine...
SOURCE: where to buy another creative blank pfaff 7570 card
I purchased a new Pfaff embroidery machine in 4/2000. A creative blank card came with the machine.The card worked fine. I purchased another blank card- Centennial PCMCIA SRAM Recharge card (bought on internet-site ? can not remember) to use when I started another project before I finished what was on the Pfaff creative card. About 2 years ago the cards( Pfaff & Centennial) couldn't hold a design over night.I tried to recharge the cards-not successful.. Now in April of this year the cards couldn't accept a design at all. In trying to transfer a design from my computer to the embroidery machine-a symbol appeared-- Computer-line connecting with- the sewing machine but no design transferred. A friend's husband suggested Allbrands.com. I bought a new creative card ($69.00) & am waiting for it to arrive. The cards that you buy with designs already on them -the machine can read and I can sew them out. No luck though with the blank cards. Denise
