Water Heaters Logo
Posted on May 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water p ump for irrigation system trips at the not my breaker turn off then back on world for a few minutes then off again over and over .help
Akbar Mughal
Level 3:
Master:
  • Master 540 Answers
  • Posted on May 16, 2019
Akbar Mughal
Master
Level 3:
Master:
Answers
540
Questions
0
Helped
121055
Points
1674
Setting is not actual...
5 Related Answers
Anonymous
  • 234 Answers
  • Posted on Mar 15, 2009
SOURCE: Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Anonymous
  • 44 Answers
  • Posted on May 24, 2009
SOURCE: no hot water. hitting reset button starts it up but keeps tripping breaker
-Did you buy it directly from Grainger? The model # is actually 82SV30-2T. The "model #" you provided is Grainger's product code.
-Is this a new installation or is this an older water heater?
-Is this wired to a 25 amp breaker. (It should be.)
-Did you re-use existing wire? If so, is it at least #10 copper? (It has to be #10 or larger to comply with code) It isn't copper-clad aluminum or cotton over rubber insulated, right? (It should not be)
-Have you re-wired the heating elements? If so, you need to restore the wiring to the way it was configured from the factory.
Let me know if you need further assistance.
V/R
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 03, 2010
SOURCE: trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Anonymous
  • 351 Answers
  • Posted on May 03, 2010
SOURCE: I have a rheem 81VP2S Electric water heater it
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Anonymous
  • Posted on Oct 02, 2011
SOURCE: Breaker trips; reset breaker at
For many years electric water heaters were wired with #10 wire with a 30A breaker, as water heated technology improved in the 1990's water heaters did not NECESSARILY need to be on a 30A breaker anymore, many electricians began to install #12 wire and a 20A breaker, during normal operation the water heater drew 17A, as the water heater collected sediment over time the current draw increases and may trip a 20A breaker, I would suggest checking the wire and breaker combination and if it is #12 and 20A, you may have to upgrade to #10 and 30A
Junkers Euroline GAS tankless water heater trips breaker??
Your issue will be on the input or mains supply side of your electrics.
Check your wiring for keakage to earth.
2answers
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
1helpful
I have a Rheem Warrior Class Model 72-52-2 240/208 wattage, manufature date 9-2005 in a trailer house. The breaker keeps tripping. When I reset the breaker, it will heat for a minute and then trip again....
Yes it is most likely shorted out to test remove the wires after you have disconneted the breaker turn off the water and drain water then remove it and replace it.
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
