SOURCE: 1993 buick skylark serpentine belt removal
there is going to be a tensioner pulley near the front of the motor on top that you have to apply pressure to or you can loosen the alternator and take it off that way,just remember how it came off so you can put it back on
SOURCE: how do you loosen the serpentine belt
remove air filter box completely. loosen o/s/f wheel. jack up the car, and secure. remove wheel. remove plastic shield to expose the cranckshaft pulley.check routing of the belt for replacement. on top of the tensioner there is a square, about 1/2 inch, place a bar in the square and gently push the bar towards the front of the car to release the tension, and remove the belt. change any defective pulleys. refit the belt leaving the top pulley till last.take up the tension of the tensioner, and then fit the remaining belt. make sure the belt is sitting right in it's grooves, and crank the engine first to make sure it is fitted ok. refit air box, plastic shield and wheel.
SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
To install:
Alternator Belt
To install:
Power Steering Pump Belt
To install:
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
SOURCE: The drive belt on my 757 ztrac mower keeps coming off.
Check to see if the idler arm at rear of machine where belt comes off PTO is bent or bushings wore out.Ask your dealer if there is any guides you can install around spindle pulleys.
