Health & Beauty Logo
G
Gene De Boer Posted on May 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find throttle pot for rascal 245 mobility scooter
Jeff Bird
Level 3:
  • Health & Beauty Master 1,348 Answers
  • Posted on May 16, 2019
Jeff Bird
Level 3:
Answers
1348
Questions
0
Helped
363072
Points
4615
Hi monster scooter parts have them complete assembly
cost $131.99 phone number
800-798-0325. cheers
5 Related Answers
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jun 13, 2009
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Anonymous
  • 61 Answers
  • Posted on Mar 19, 2010
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Anonymous
  • 692 Answers
  • Posted on Sep 10, 2010
SOURCE: manual for rascal mobility scooter,
Bub see the following web http://www.rascalscooters.com/index.cfm/mobility/service.manuals
I don't know if they list your model but they have an 800# you can call to get help Hope this helps you
Anonymous
  • Posted on Oct 03, 2010
SOURCE: I have a Rascal 245 Mobility Scooter which is 3
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Anonymous
  • 2418 Answers
  • Posted on Apr 12, 2011
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Rascal 245 Mobility Scooter. How to change the battery on a Rascal 245 please?
Question edited for clarity.
Question moved to a better category.
Check out the video and there are links to suppliers.
https://www.google.com/search?q=rascal+245+change+battery
2answers
I replaced the speed pot and throttle pot now my rascal 235 drives but only about half speed
Sounds like one of them has incorrect values. You need to check the resistance marked on the original speed and throttle pots, with the new ones. Generally a throttle pot is 5Kohms and 20 or 200 ohms for the speed pot.
2answers
I replaced the throttle pot asmy.on my Rascal 245. no speed. need a manual or schematic
hi, can i ask where you got the throttle assembly from ?
Regards
www.gewizrepairs.co.uk
1helpful
2answers
I have a Rascal 200..was working fine..now after you go forward and let go of the throttle. ..it goes in reverse itself. .is there a throttle adjustment?
I had a similar problem on my Pride Legend scooter, it would
creep back in reverse if you let go of the throttle. The FWD/REV spring tensioned throttle pot inside was "off center"causing it to activate in reverse when it should have stayed put with the electric brake energized.
I had to replace the throttle pot assembly. Not sure if yours
is similar, but I would suspect it might be.
2answers
Rascal Scooter model 245
If the throttle is stuck a little bit then it may not let you start it while the throttle is on
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
5helpful
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
2answers
I have a 245 Rascal Scooter. I need to know if I can lower the seat?
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
