Question about Locks & Locksmithing
Protex digiPaz-307. Battries dead. Cant get overide wire. Product discontinued. Batteries to change are inside safe.
    Top Expert:
  • 21,173 Answers
Manufacturer or locksmith
Posted on May 15, 2019
SOURCE:
Is there a factory reset for protex wall safe pws1814e
refer to the manual that came with the safe it will have a master code included or instructions on how to reset the unlock code or you can contact a lock smith or the manufacturer and they will be able to assis
Apr 29, 2014 | Safe International Protex Wall Safe...
Batteries have gone dead how do I change them?
if you open your safe you will see on the inside of the door there is a lid that looks like the same at the back of your tv remotes. The batteries are kept inside there. You will find it normally use AA batteries. Hope this helps
Jan 02, 2013 | Safe International Digital Electronic Safe...
I have a bunker hill safe ,item# 91006,batteries too low,no key, drilled out overide lock,still won"t open, now what?
you can also get some wires feed him into the back contacting the battery terminals hold in there with a 9 Volt, four hands and patieance and then..... you get my drift. Worked for me! :) $
Dec 26, 2012 | Computers & Internet
I MISTAKENLY LOCKED UP MY SAFE KEY INSIDE THE LOCK AND THE BATTERY IS TOTALLY DEAD ,PLEASE I NEED HELP
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
Nov 20, 2011 | Locks & Locksmithing
I have a digipaz 309 electronic lock safe. after enterring * -6 digit code-# the i get a beep and 1 flash of LED light, but the handle won't turn open.
I have a digipaz-309 save and it is not allowing me to close it. I have change the batteries not sure what to do it's not giving me any light at all
Aug 20, 2011 | Protex Safe Ul Rated Fireproof Electronic...
How do you know with direction to put the battries in as their is no markings, Does it not have a polarity?? also how many and what size battries does a GVD -505A Live Wire take
Just changed my batteries 2 LR44 batteries positive side goes toward the back of the device, There are no markings on the holder to determine polarity!
Mar 15, 2010 | Acer Gardner Bender GVD-505A LIVE-WIRE...
Just purchased it used. Both battries show
If the horn won't work, the batteries are dead. If the charger is showing green lights, most likely the gel inside the batteries has gone solid from the chair being stored for a while. Replace both batteries with type U1, 24v, 33 amps and see if that will clear the problem. The fuses are regular automotive type fuses.
Mar 06, 2010 | NRS Hoveround MPV 5 - Used Power...
How do i know when to replace batteries ?
There's no sure way to know when to change the batteries. I'd suggest you change them at least once a year. Plan on it when you do your smoke alarm battery change, which should be done at least annually.
Jan 26, 2010 | Weiser Lock Powerbolt 1000 Lock
Battrie wont last
You probably need to replace your batteries again most batteries in a owc need to be charged 12 hrs a day for the first month at least to build up the capacity if not they will slowly dwindle and wont last long and will need to be replaced
May 29, 2009 | Pride Mobility Products Used Jazzy...
I cannot open my sons Science Museum Lock N safe Money Box
here is the default code, start by pressing mode so you go into code mode, tehn turn the dial left to 0, then right to 1, then left left 0,then right to 3 then turn dial right and your safe will open!!!!!
Jan 15, 2009 | Toys
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
