SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
SOURCE: wet dishes
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan
Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat
Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
SOURCE: Dishwasher not drying
the dishwasher does not have a heating element to dry the dishes. If you wash glass or ceramic dishes and cups then the rinse cycle makes them hot enough to dry without a heating element but if you wash a lot of plastic this process does not work very well. Open the door after the load is washed and leave them to air dry for several hours and you will be fine.
The manual states that there is no heating element to dry dishes. The high heat content of porcelain, glass, or metal dishes enables them to get hot and stay hot long enough to get dry without a heater. Plastic does not have nearly as high a heat content so they cool down much more quickly and don't get dry.
SOURCE: frigidaire dishwasher - no heat coming on to dry the dishes
Did you ever learn why the heat was not drying dishes? We have the same problem.
SOURCE: we have a FGHD2433KB1 model
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things...
Bought new spray arms online and installed them inminutes...now the thing works like new...
However I have also found that if the heating element goesbad then that also can mess things up bad...
So I would buy new spray arms, and also check out theheating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker
