SOURCE: freezer coils frozen, 27 deg. freezer and 45 deg. fridge.
the problem is most likly to be the freezer gas has lost its "get up and go!" and needs a "re-gas" and if the compressor is running all the time that could also need changing by now
SOURCE: Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
U need to change the main control board which is located under the bottom front. Pull the kick panel off and u will see a black box with a 1/4 inch screw holding it up. Remove screw and slide forward. U will also need to change the display board on ur dispenser so that the software matches. Its communication error between the 2
