Track Saw vs Circular Saw-which is best for your project
March 19, 2020 By pervezWe use a saw for cutting wood or any material. In the market, we can find a lot of saws and it will do our desired work. If you are a woodcutter then a track saw will help you. A track saw is a handheld circular saw, on the other hand, a circular saw is one kind of power saw which helps to cut woods or any material.We can use track saw and circular saw for cutting woods and other materials like tile, brick. But there is a difference between them. We have to know what is Track Saw vs Circular Saw. see the difference between them given below.
Track Saw vs Circular Saw Lets Have a quick look into these
A user uses a saw for different cutting purposes circular saw and track saw is one of them. The track saw is used for cutting woods and circular saw also used for cutting woods too But both of them are used for different purposes.
Circular Saw
We use a circular saw for cutting woods and it uses a round blade lined sharp metal blade. A circular saw is used for cutting woods, plastic, metal, and masonry. Circular saw is an electrical saw and it runs through electricity. There are some things in a circular saw and they are-
Safety Procedure
Circular saw is a powerful tool and it is dangerous too. A user must wear safety equipment while using this circular saw. Moreover, this tool can produce a lot of dust so better is use masks for it. We have to hold the saw perfectly with both hands so that it will not move from the place.
If you have enough time then you may go through the article- Top Circular saw Buying Guide.
Track Saw
The track saw is a handheld circular saw and this helps a user to cut logs accurately. A track saw can cut any log faster than a circular saw because they are lightweight and portable. The layer on a track saw creates an effective dust trap and also doesn't just enclose the blade.
The track saw is suitable in any situation because of its rubber strips at the bottom. It is easy to cut and no need for measurement and it can make a big cut into small pieces.
The Benefit of Track Saw
Mainly a track is easy to move from one place to another place and it will give a user smooth and clean cuts than other saws in the market. Easy to cut no measurement needs to cut a log or any material just line it up and cut it. No guesswork or measurement is needed to cut woods.
Should a User Choose a Track or Circular Saw?
A track saw and circular saw both of them these are using for cutting any material or woods or a tile or metal and plastic things. The track saw is one kind of circular saw which is portable and easy to use than a circular saw.
A circular saw is a powerful and electrical saw. The user has to be careful while using this saw because any single mistake can risk his life. So if a user loves to use a handheld saw then he should go for a track saw and if he wants a powerful saw then he should go for a circular saw.
Circular Vs TrackSaw
Track saw and circular saw both of them use a circular blade but track saw blades are less uncover. The major and main difference between them is one is easy to move another is complex to move. Another difference is track saw provides a better cut and smooth performance than a circular saw.
Circular saw creates more dust than a track saw because in a track saw a dust filter contain on it(track saw). The circular saw is best for construction purposes because it can give you the best performance than a track saw. If you are going to cut lumber or a tree on a roof than a circular saw can help you better than a track saw.
So better is if a user wants to use a portable lightweight saw than track saw is better for him. But if he wants to use a saw that provides more facility than circular saw is for him.
Final Words
Both of this saw is perfect for cutting wood or any kind of material. A track saw is portable and lightweight on the other hand a circular saw is more powerful than any other saw. You can carry a track saw with you in your shoulder but can't carry a circular saw with you.
So if you want a lightweight saw then track is for you or if you want a powerful saw then circular saw is for you.
Filed Under: Guide
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
SOURCE: I have a Item #9100 Powershot Pro Electric Staple
I just purchase the powershot 9100 I can't get the trigger to work for the staples to come out. What am i not doing correctly?
