Question about Radio Communications
How do i get rid of public safety stuff on my scanner
I would like to know if there is away I can print out the frequencies & channels for Monterey, Calif Thank You
Yes, go for it :>)
  • Monterey County, California (CA) Scanner Frequencies and ... www.radioreference.com > US > California Scanner Frequencies and Radio Frequency Reference for Monterey County, ... Monterey County California . ... Monterey Regional Waste Management District : FM :
  • N6SPD : MONTEREY PENINSULA POLICE FREQUENCIES n6spd.com/freq/mcfreq.htm 155 rows · CHANNEL # FREQUENCY: TONE: SHERIFF: North Dispatch: 1: 159.090: ...
    • AGENCY TYPE CHANNEL # FREQUENCY SHERIFF North Dispatch 1 159.090 CAL FIRE North Dispatch Command 1 152.720
  • Monterey County Scanner Frequencies (CA) - Intercept interceptradio.com/slocal.php?disp=1&country=US&state=CA&county=... 39 rows · Home of the world's largest radio/scanner frequency database ...
    • Freq PL/M City Call 51.76 114.8 Monterey WE6R 51.82 136.5 San Ardo WR6VHF
  • Monterey Park Scanner Frequencies (Los Angeles County CA) www.interceptradio.com/slocal.php?disp=1&country=US&state=CA&county... Scanner Frequencies for Monterey Park Los Angeles county CA US. ... Los Angeles County Scanner Frequencies (CA) ... Channel Notes;
  • View and Compare Your Scanner Options ' Police Scanners www.policescanners.net/scanners-ca-monterey View and Compare Your Scanner ... About Us; View and Compare Your Scanner Options Monterey County, California Fire Police ... Fire and EMS channels in ...
  • California: Monterey - Radio Scanner Frequencies www.scannerfrequencies.com/radio/california/monterey/page/2 Scanner Frequencies ... USA CA Monterey. Articles Contact Submit. Follow @ScannerFreqs. California: Monterey. Frequency: CallSign: DBA/Licensee: City:
  • California Public Safety Frequencies - Bay-Net www.bay-net.org/frequency_calif.html 866.2000 - Channels 20 & 21 - Northern California. ... to air tactical frequencies. In southern California FIRESCOPE area ... California Public Safety Frequency ...
  • Monterey Park, California - Scanner Frequencies - Phone ... www.cityfreq.com/ca/montereypark Scanner frequencies, phone numbers, ... Monterey Park, California Scanner Frequencies. Public Safety. AHMC MONTEREY PARK HOSPITAL (CARMEN ...
  • FCC Licenses and Scanner Frequencies for Monterey County ... www.radioreference.com > US > California > Monterey (County) FCC Licenses and Scanner Frequency Listing for Monterey County, California ... US > California > Monterey (County) County Home;
  • Monterey County Frequencies - Scanning California www.scancal.org/old/monterey/county.html Monterey County Napa County ... Scanning Central & Northern California Frequencies Monterey County Last Updated: ... Channel 2 - Secondary
  • Feb 04, 2016 | Radio Communications
    Safety will not release
    [PDF]Record Request Form - Oklahoma Department of Public ...
    https://www.dps.state.ok.us/.../rrct...
    Oklahoma Department of Public SafetyDepartment of Public Safety. RECORDS REQUEST and CONSENT TO RELEASE ... The Department of Public Safety does not issue National Driving Records.
    Safety (firearms) - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Safety_(firearms)
    WikipediaIn firearms, a safety or safety catch is a mechanism used to help prevent the ... grip isreleased, the firearm is decocked, and the single-action trigger will not cock ...
    [PDF]Request To Release Personal Information
    Dec 05, 2015 | Cars & Trucks
    What is ment be reflashing a police scanner
    • When police, public safety, etc re-band then some scanners may not pick up the frequencies and you need to update the firmware (when available) to keep your scanners ability to monitor certain frequencies, pairs of frequencies, splinter channels etc.
    • Hope this helps.
    Regards, Tony
    Oct 17, 2011 | Radio Shack Pro-96 Scanner
    Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
    Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
    Sep 21, 2011 | Radio Shack Pro-82 Scanner
    Uniden BCD396XT...........I programmed my channels with my computer. I cannot get back to them...........I will pick them up when I turn the unit on then it scans public safety............
    BCD396XT
    While the unit is scanning the public service band (or other
    preloaded like NEWS etc) press the Func button once, located on the left side
    (the top one). Now within one second press the L/O button twice. This
    permanently locks out that system. Pressing the L/O button only once will lock
    out that band only until the next time you turn the scanner on, then it will be
    back.
    Jan 22, 2011 | Uniden BCD396XT Handheld Scanner
    Can you listen to a police frequency if it's trunked with this scanner? Uniden BC72xlt
    You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
    Oct 16, 2010 | Uniden BC72XLT Handheld Scanner
    I am looking into getting the Uniden Bearcat BC60XLT1 scanner Is this scanner capable of trunking? I guess my local police dept uses trunking freq.s
    This scanner does not do the 800 Mhz trunk tracking that you are looking for. A synopsis and link to the manual can be found below:
    http://www.usascan.com/files/bc60.html
    Typically, a trunk tracking capable radio will cost in excess of a couple hundred dollars - significantly more depending on digital capabilities.
    Your first step should be determining which services (public safety, public works, ambulance, taxi, military, ham, etc.) you're interested in monitoring. Next, list the communities in your area and search for the frequencies they use. You can find this by googling the Town,State Scanner Frequency like this:
    Boston, MA scanner frequencies
    Broaden your scope by substituting your county for the Town or simply search on your state. You should find links to entire directories of listings, and groups of people interested in scanner monitoring. Talk with those people or store sales personnel about a particular scanner's suitability to monitoring a certain type of service, frequency, mode, etc.
    Once you've collected this info, do some research on equipment and see what fits in your budget. Ask questions in user groups for scanning and radios, too.
    I hope this helps - good luck!
    Mar 26, 2010 | Audio Players & Recorders
    Threre is a key in theupper left that i can't get rid of and can't get to another scanning mode Scanner 82 from radio shack
    Press and hold the bottom left key (looks like a light bulb with a key above it) until the key on the screen disappears. That will release the safety lock and restore the scanner's normal functions. Need the manual for your scanner? You can download/print it here:
    http://support.radioshack.com/support_electronics/doc69/69887.pdf
    Nov 03, 2009 | Radio Shack Pro-82 Scanner
    I'm tring to find codes for a police scanner for henderson,ky.
    RadioReference.com is the world's largest radio communications reference website, featuring a complete frequency database, trunked radio system information, FCC License assignments and callsign maps, 10-Code Lists, agency maps, files, downloads, links, and detailed agency information for most public safety, military, and local government communications.
    Best of all, registration and access to all the data is free, however some special reporting features and downloads are only available to Premium Subscribers of the site.
    that should solve your problem
    Jan 11, 2009 | Radio Shack Pro-95 Handheld Scanner
    Radio Communications Logo
    20 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
