Plugged exhaust , catalytic converter ! Have exhaust back pressure tested , and while your at it have the fuel pressure an flow tested . Also have a professional tech do a look see at scan data .
Hey have you tried disconnecting and re connecting the battery? my mitsi carisma startd doing that so i rang up dealer and aparently they do it when the computer thinks there is something wrong with the engine, so it enters slow mode (or turtle mode or something) so that minimal damage is done while you drive it slowly to yr mechanic. Could be complettly wrong tho. Good luck.
FIRST CHECK OIL PRESSURE IT SHOULD BE 30 - 80 PSI AT 3000 RPM.IF NOT YOUR OIL PUMP PRESSURE REGULATOR FAULTY.IF ALL IS GOOD OIL + FILTER BEEN CHANGED.POSSIBLE CAUSE TO NO OIL FLOW TO THE ROCKER ARMS COULD BE PLUGGED OIL PASSAGES IN ENGINE BLOCK.SLUDGE BUILD UP IN OIL PAN CAUSING POOR OIL PICK UP.OR WORN DIRTY LIFTERS WONT PUMP OIL.
