SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch. Change the battery, and see if the problem goes away. If it does not, then it could be a problem with the stepper motor, which will require a watchmaker. Of course all of this is dependent on the assumption that your watch has a quartz movement. If it is an automatic, or mechanical you have bigger problems.
SOURCE: tv has a pink smudge across the top of the screen
Your
convergence has failed and need to be repaired. Once quick test is to
goto your convergence menu and see if you can adjust red and blue. If
not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
SOURCE: step count not accurate
The sensor is not necessarily counting steps as much as motion that is enough to be considered to be equal to a stepping motion. Positioning the device differently may result in a more accurate count.
SOURCE: How to reset steps on my Fitbit charge 2
hi Vicki.
this is all i can find out.
How do reset steps to zero
or this.might be of more help to you.
How to reset steps on my Fitbit charge 2 Google Search
