Question about JVC LT Televison & Video
How do I connect a JVC LT-32N740Q Led Smart TV to a wireless fibre HUAWEI router?
SOURCE:
ronenfe
  • 91 Answers
SOURCE: how to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Posted on Mar 03, 2008
  • 16 Answers
SOURCE: Hg520s Huawei wireless router
Make sure you LAN settings is looking at your Wireless Adapter for WAN source, your computer might be looking up to the Wired Adapter for source, with not much info that's all i can suggest.
Create a new connections and make sure Wireless Adapter is selected.
Hope this helps
Enjoy
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
Posted on Apr 30, 2008
  • 58 Answers
SOURCE: how can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
  • 205 Answers
SOURCE: cannot connect ds to wireless router - Huawei Echolife 520s
Ensure that the B type is enabled in your router and that the security it set to WEP and that your passcode is correct.
HTH
Posted on Oct 28, 2008
SOURCE: Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Posted on Dec 12, 2010
My Jvc smart tv won't connect wireless to my router .
yeah you can delete it again and configure the way your did it before but if you don't know how to connect using the router back again to your Jvc smart tv then ask guidance to experts
Jun 10, 2018 | JVC Computers & Internet
Why would my samsung smart tv won't connect to my belkin a46 router.
Although there is a menu for wireless connection, unless you purchased a separate SAMSUNG wireless LAN adapter, you cannot use the wireless connectivity functions of the TV. You can use the regular wired LAN connections however. (see users manual for more details
http://downloadcenter.samsung.com/content/UM/201103/20110324091218633/%5BENG_US%5DGSATSCA-1017.pdf
Mar 01, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Hiw do i connect my tv to the internet? 8ts a bush 40" full hd led smart tv
You really need to read the manual to your TV. You need to have a router connected to a high speed Internet service. If you mean connect to the Internet, your smart TV will,have to have a browser, like Opera to enable you to get online. The smart TV apps are selectable with your remote, but you have to get the connection first. If you don't have high speed Internet and a wireless router it ain't gonna work. I don't have the manual to your set, so I can't tell you the exact steps you use on your remote control.
Jan 24, 2015 | Bush Televison & Video
Why can't I connect to wireless?
you need a type G or above router that has the wps trigger button
or a type G wimen that can allow you smart TV to connect to the right protocals
its all a matter to the TV whats avalible on the wifi router
if you have a GH modem then look to upgrade
Nov 30, 2014 | Vizio 50-Inch LED Smart HDTV 1080p Full HD...
Smart led manual
optical or digital if amp has these connections
Sep 02, 2014 | Audio Players & Recorders
Cannot connect to my wireless network
Recheck your router to see if the mac address of the TV is listed on the wifi setup page. On the TV, make sure the router password is entered correctly
Jul 23, 2014 | Hisense 50 Class 1080p LED Smart HDTV -...
Cannot conect my jvc 1080p fhd lt-46n920 tv to the wifi
You must enable the mac address of the TV on your routers wireless menu. Once you access the router enter the wireless setup tab and select MAC filter. Enter the mac address there and check the enable box and the permit box. Save the changes and your tv will then connect to wifi.
Jan 05, 2014 | JVC Televison & Video
Can't get the TV/router connection made
double check the password, some are case sensitive. Also make sure you don't have mac filtering used on your router. If you do, you will have to enter the mac address of your TV before it will connect or turn off the mac filter. Also is your router set for DHCP or are your IP addresses manually assigned?
Oct 18, 2012 | JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV...
No power on TV - JVC LT-47X788 47 in. HDTV LCD
Power supply board is dead.U have a LED light indicator on LCD panel flashing?The tv is completely dead,no LED light at all?Tries Website like Shopjimmy.com.Ebay.com to buy a refurbish power supply for the replacement.
May 07, 2010 | JVC LT-47X788 47 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
