SOURCE: my old panasonic crt tc 33v2h has lost color and shows a ghoulish green..any help!
Check for any loose solder points at its base card. Resolder all suspected solder terminals by applying a little more fresh solder.
SOURCE: my old crt panasonic tv model tc 33v2h has lost color and shows a greenish hue.
My panasonic tv is 17 system/CATV HYPER-BRAND and it is blasting fuse whenever i changes fuse it blow up and fuse that is because voltage is been doubled after that happened so plz give me suitable process to correct my tv thanks friend
[email protected]
SOURCE: panasonic tv
There should be some short circuited component/s in the circuit board. Your TV need a through check up. Contact any service technician.
SOURCE: how to adjust vertical height for panasonic crt tv model number TC-2119R
To adjust height and other parameters, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
