sachin saxena Posted on May 14, 2019
LSU unit failure: #u2-1112 samsung ML 1666 printer kaise thik hoga pls ans send me.
5 Related Answers
Anonymous
  • 81 Answers
  • Posted on Jun 09, 2008
SOURCE: Samsung ML-2010 LSU Error
It sounds as though the laser went out. Its not too bad to replace, but you would need a service manual. Be sure you can get the part first, I checked my usual suppliers and could not find one. If you do replace this yourself, be sure to follow all the safety procedures.
Anonymous
  • Posted on Nov 27, 2008
SOURCE: Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Anonymous
  • Posted on Oct 22, 2010
SOURCE: we want solution for samsung
Samsung printer error: Sensor error A3-3112
Anonymous
  • Posted on May 27, 2011
SOURCE: samsung printer ml-1640 lsu error
my printer ml 1640 is not pick up page and show a troublesuting error printer system error
Anonymous
  • Posted on Sep 14, 2011
SOURCE: reset samsung ML 1666
i was reset the samsung ml-1666 by using of chiprest utillity but printer is (asking )change ml-1640 insted of ml1666 what i do plz help me
Samsung ml 2551 Engine hsync error
Dear The problem is with LSU (laser scanning unit) unit. If you are experience open the lsu clean all optical path and test. This may operate .Replace the LSU unit.Thanks.
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
5helpful
Firmware of ml 1666
need for samsung ml 1666 chipre set software
I was reset the samsung ml-1666 by using of chiprest utillity but printer is (asking )change ml-1640 insted of ml1666 what i do plz help me
Dear
You have upload the firmware of ML-1640, which is not possible. Try to upload ML-1666 firmware fix. You can also try covering a tape on the chip contact area only.
Thanks.
My printer is showing the error LSU Hsync power error
hello,
your Ml 3051ND printer have bad laser scanner unit(LSU UNIT)you have to replace this unit.best thing is call for service.
or some time laser scanner unit wire harness was damaged. so best solution is call for service.
1helpful
Reset samsung ML 1666
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
k24674
ADMIN Andrew
ADMIN Andrew
