SOURCE: won't turn on, take charge, communicate
I have the same one and let it go dead all the time. It will take 5 - 10 minutes after you plug it in for the blue light to come on when it's dead. Mine recently decided to WOULD NOT charge. It turned out to be the three little pins on the charger were dirty and sticking. I used a cotton swab to clean them with some rubbing alcohol and a quick dab on the contacts of the headset. Works great now.
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
SOURCE: wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
