SOURCE: My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
SOURCE: Sony Explode 4 channel amp in protection mode
sometimes if the power cable and the ground cable are frayed and touch it will short out the amp temporarily check to make sure allof the wires aren't touching each other
SOURCE: Lanzer vibe 416 1000watt Amp stay in protection mode completey
I'm no pro but I've fixed a few amps in my time.When you had the 12's hooked up it was working fine you say,but when you upgraded to 15's is when the problems started. You probably bridged it too low of ohms and it maxed the amp out,it got too hot and started to burn up the channels. all that matters when you buy speakers and amps. The 12's was probaly 4 ohm coil speakes and the kickers are 2 ohm. The kickers bridged together positive to positive, negative to negative would bring it down to 1 ohm load witch I dought the lanzar can handle. If your a fix it yourself kind of person like me. I can point you in the right direction on where to looke for parts to fix your amp....
SOURCE: Nad C350 2 channel Amp continually in protection mode
here is the solution to your problem,you will have to visit this forum for the fix.
Click HERE
Goodluck,
Please don't forget to rate the solution
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
I'm Having the same issue. A little help would be appreciated.
un plug the speakers first
if still OVerload the amp is blow out and needs service.
