Factory radios are connected to the Body Control Module computer and are monitored and run by it. Things like warning chimes and indicator clickers are instigated from the BCM and sent via the audio system. You replace the radio with something the BCM doesn't understand and funny things happen. An auto-electrician or a radio / alarm outlet might be able to reprogram the BCM to ignore the new audio device.
Put the old radio back in and it will be fine.
SOURCE: phase linear double din
hook up a switch solve all your probs, no codes yet **** i will let ya know when i find one.
SOURCE: USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
SOURCE: I JUST BOUGHT A NEW HEAD UNIT JVC DOUBLE DIN DVD
If hooked up to amp turn it down. also try on ur head unit also
Maybe is too late, but i wrote here what I found about LITEON PA1181-08 adapter.
First flip the adapter and remove those 4 round rubber where you will find 4 screw's. Or take a look here => http://www.pchub.com/uph/laptop/46-33144-7053/LITE-ON-PA-1181-08-AC-Adapter-Laptop.html for pinout of the unusual 4 DIN connector.
Hope you will find this usefull.
[email protected]
Yes it will fit, you will have to buy a seperate mounting kit for the new radio though.
