Question about Radio Communications
I hip bluetooth black minibar will mot pair - Radio Communications
2 Suggested Answers
SOURCE:
ahlrub
  • 283 Answers
SOURCE: Moto razr will not hold pairing to Bluetooth
ook .. man try to do this. but first back up u'r fone,. here it is! go to menu, settings, initial set up, master clear code ( 000000 ) fone boots just w8,, then go again to menu, settings, initial set up, master reset code ( 000000 ) fone boots and now do your things,.. let me know..
Posted on Apr 28, 2008
I lost pairing on headset and iPhone. Tried to pair again but headphones won't pair with my iPhone now.
Pair your device with a Bluetooth accessory
  1. On your iOS device, tap Settings > Bluetooth. Stay on this screen until you complete the steps to pair your accessory.
  2. Place your accessory in discovery mode and wait for it to appear on your iOS device. ...
  3. Tap your accessory to pair.
Set up and use third party Bluetooth accessories
Mar 09, 2016 | Yurbuds Liberty Bluetooth Headphones Black
How to pair my smart phone to my i hip sound machine
Turn on the bluetooth and find the device. May need to hit search for devices
Mar 04, 2015 | Cell Phones
I have a mot g which I have paired with my Peugeot 207 but incoming calls only show a number not the caller I'd.???
Hello! In this the issue could be with the device or with the car. You will have to make sure that both devices have the right profiles. You can look for this information from our Motorola website: Using Bluetooth and from: Bluetooth PBAP maemo org wiki.
Try to set up another phone with the car and the Moto G with another car to see if you have the same problem.
Best Regards
Karen
Customer Support.
Aug 14, 2014 | Motorola Cell Phones
How to pair bluetooth keyboard
On the tablet, Setting/Bluetooth, turn Bluetooth OFF.
On the Keyboard, switch on.
On the tablet turn Bluetooth ON.
You should see the tablet searching and when found click on the device and click PAIR.
Aug 14, 2014 | Dell Venue 8 Pro 64 GB 8" Wi-Fi Black...
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
Bluetooth pairing code
Cantz bluetooth speaker sometimes pairs with tower and as often not.
Jan 04, 2014 | Ergoguys HS-BTV60S-BL Hip Street yak...
My LG CU920 will not accept my Mot HS850
u will need to contact the manufacter of the bluetooth for assistance
Jan 14, 2010 | LG Vu CU920 Cellular Phone
Apr 28, 2008 | Motorola Mobility RAZR V3
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
18 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
