SOURCE: i need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
