Hello John, comment that brand and model of amplifier you have and what equipment is connected to the amplifier
This is to find a best possible solution
I await your comment
Greetings Franco Dosil
Hola John, comenta que marca y modelo de amplificador tienes y que equipos est?n conectados al amplificador
Esto es para encontrar una mejor soluci?n posible
Espero tu comentario
Saludos Franco Dosil
SOURCE: i have marshall 250 dfx when i turn it on cooling
Try carefully cleaning your cooling fan with qtips for the blades and a vacuumn. See if that helps the fan. If not it will need to be replaced. If you are experienced with amp repairs have a look for loose parts on the circuit board. If you can safely disassemble it, look at the soldered side for bad solder joints. From another poster on here with the same problem I have learned that resoldering R107 and R96 helped. Make sure they aren't burned out or have changed in value.They are in the FDD circuit. Have a look at your owners manual and it will make sense. The schematic is available here:http://www.ampix.org/displayimage.php?album=search&cat=0&pos=0 If it doesn't come up use the search function on that site. Do not attempt to service this yourself unless you are absolutely sure you won't hurt yourself or the amp.
