Question about Watches
My Omexey is 22 minutes slow. How can I get it to correct time. Model RTO188
My atomic watch is 5 minutes slow, do not know how to change the time to the correct setting
I would suspect that your watch is not picking up the radio signal to reset itself to the correct time. There are several reasons for this - the battery might be very low, or you are in a poor reception area, or you are just too far from the transmitter, or the hands need realigning. If the watch claims to pick up multiple transmitters, then be sure that it is set to the correct one. Try taking off the watch at night and placing it face-up on a window sill to give it the best chance of a signal.
I can't offer anything other than general advice as you do not give the make/model of your timepiece. Some radio-controlled watches have a facility to realign (or 'zero') the hands - again, can't be specific without more information.
Nov 29, 2016 | The Watches
Casio wave ceptor hands running 8 minutes slow. Digital clock showing correct time. Hands 8 minutes slow even if I change time manually.
You may need to recalibrate the hands. Sometimes the hands are out of sync with timekeeping. Go to the Casio website, download the manual for your model, and follow instructions for resetting the position of the hands (might be referred to as zeroing or recalibaration).
May 30, 2016 | Casio Watches
My Casio analogue display is showing 5 minutes slow whilst the digital display shows the correct time
If old model ana-digi watch you have to manually synchronize analog time with digital display.
Nov 15, 2015 | Casio Watches
My Oceanus watch model no. 4749 stays 1/2 hr slow. I manually reset it to the correct time and it resets itself to 1/2 hr slow. I have it set at central time
You can get manual information from the Oceanus web site (NOT casio strangely enough!).
Insert "www.oceanus-us.com/" into your search engine
Select "support", then "Manual information"
Enter your model number and download the information. There are instructions on choice of home city and further adjustments if it still is not correct after initial setting up.
Jan 16, 2010 | Casio OC500 Oceanus watch
The watch is 2 minutes slow I know how to change the hours, but I am not able to up the minutes
Use the button, that you use to go to the hours setting and keep pressing it, until the minutes flash. Bump the plus or minus button until you have the correct time. Bump your way through to regular running time.
Nov 12, 2009 | Timex 1440 Nylon watch
Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Bulova Watch
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Watches Logo
32 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
