SOURCE: how to find and replace a freeezer door seal
on many models, it is not possible to fit a replace,ent door seal - they are foamed into the door and to replace the seal means replacing the whole door
SOURCE: How to replace the door bellows seal ?
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
SOURCE: Replaced magnetic seal on freezer and door still
depending on where the gaps are your hinges are warped. losen up the hings bolts and adjust hinge then hold in place and retighten bolts
SOURCE: the seals on the doors need replaced. THEY leak
You can peel back the seal looking behind it and there should be screws all the way around it.
Or you problem could be caused by-
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
SOURCE: WHY CAN'T I HERE THE VACUUM SOUND ANYMORE WHEN THE FREEZER DOOR SHUTS?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
