That depends...
It depends on how much the repair will cost and how long it will be before another repair is needed - these are unknown quantities but you could ask your local repair shop and a Panasonic dealer how much for a repair estimate.
Mostly if you go ahead with the repair the cost of the estimate will be waived. If you don't go ahead you should be able to negotiate the estimate cost as a discount off a replacement - if you use a Panasonic dealer.
10 years of hard work from a premium microwave should be as nothing when you consider my old Sharp Carousel lasted me 29 years of daily use, but then things today aren't built as well as they used to be.
I suggest you decide on the cost of a likely replacement model before you go ahead, follow the link below to begin your search. In the final analysis a repair is a bit like making a wager while buying new with a warranty is like putting your money on the favourite...
https://www.panasonic.com/ca/consumer/home-appliances/microwave-ovens.html
SOURCE: Microwave turns, gives out strong burnt plastic smell, little (or no) heating
I would first suggest that you look inside the cooking cavity to see if your wavegudie cover is burned or carbonized. If so, it will need to be replaced. You can order one via Tritronics at http://www.wehaveparts.com The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Once you remove and / or clean the cover and clean the opening of the waveguide, if it still won't heat and/or still has the smell, you may have a bad magnetron or high-voltage transformer. Feel free to post back if you still have trouble.
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
SOURCE: scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your
