SOURCE: Door latch is in "LOCKED" position however the door is open!
It is possible that you have a problem with the door?s sensor, maybe it?s turned off or maybe some water fell on it. This is the reason why the micro controller interpret that the door is still open, and that?s why the washing procedure does not start. You have to find the manual and determine where is the location of the sensor and then see in what state it is (Turned off, wet, or damaged)
SOURCE: My security system continues to
I have a 1992 Acura Legend. If the alarm goes off when you open the door when the alarm is set you may have to close the door and put the key in the door lock and turn it clockwise to turn the alarm off.
SOURCE: 1995 Chev Suburban rear door latch stuck in locked position
sounds like you lached the door
use a screw driver or some such tool
lift the outer handle and slip your tool in the middle of the lock hole in the door flip the lach open wile holding handle up
SOURCE: frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
SOURCE: Trunk Latch will not pull closed.
The small switch is the trunk by the pull down motor with the flap that depresses down is at fault. That is what you call the truck pull down switch. You can take this part and show it to a Cadillac or Ford parts department sales person and get a replacement for you car. Ford uses the same part for their Lincolns and Crown Vic's. The part is made by the very same supplier for Ford & GM. Ford will sell this part at a much lower cost as well compared to GM
Testimonial: "This is correct! "
