Tools & Hardware - Others Logo
Steve Alderman Posted on May 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have brought a pro 710w sander and need new sanding belts not sure what size I need
Thomas Perkins
Level 3:
  • Master 15,088 Answers
  • Posted on May 11, 2019
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3386616
Points
54869
5 Related Answers
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Jan 11, 2009
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Editor925
Dean
  • 285 Answers
  • Posted on Mar 18, 2009
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on Apr 02, 2009
SOURCE: Porter Cable 352V belt sander eats belts
I've never had any particular problems with norton belts. All belts will require some adjustment as they wear in,however.
Try this: Put a new belt on, turn the sander upside down and rest it on the front handle. Get a good grip on the rear handle and turn it on while you use your other hand to turn the tracking adjustment. Just center the belt on the drum. I don't know what the manual tells you to do, but that's what matters, that the belt rides across the platen without hanging out loose in space or running up against the housing of the machine. If it does ride in against the housing, and you don't track it away, eventually you'll have a groove worn right through the side of the machine.
If you try this, and it still doesn't work, make sure the drums are secure and look right. Is it possible the machine was dropped and the drum bent? If so, parts will have to be replaced.
The only other cause I can imagine is that there is some kind of something jammed inside the housing that is protruding into the belt pathway that they're getting caught on, but that seems unlikely. Check anyway. Look with a flashlight.
There are better belts available than Norton, but they should work.
Some belts have an arrow on the inside of the belt indicating the direction of travel. Make sure if yours does, that you put it on that way. I try to install them so the joint will tend to ride up over the work instead of the work tending to want to tear the joint apart, but this is not always obvious, depending on the mfr.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Anonymous
  • 154 Answers
  • Posted on Apr 14, 2009
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Anonymous
  • Posted on Sep 13, 2010
SOURCE: what is the belt size of a skil 593 belt sander?
2 1/2" x 16"
1helpful
On a Toledo 800 bets sander c ou ld I ask what size is the sand belt please? Thanks
I'm assuming you're referring to the belt you're actually sanding on. For the TBS800 model the belt is a 75 x 533mm size. Try this website for a owners manual.
https://www.manualslib.com/manual/1381717/Toledo-Tbs-800.html?page=2#manual
2answers
1helpful
Ryobi belt sander
is the motor turning the drive roller if not it could be brushes or new bearings ,or the other roller might need oiling ,and if none of this is right it may be the wrong size belt cheers
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
2helpful
CHANGE THE SANDPAPER IN THE BELT SANDER
there should be a lever that will loosen the tention on the belt so you can get it off. be sure to put the new belt on with the arrows facing the rotation (some sanding belts do not need to be oriented this way, but check) otherwise the belt will come apart after a few rotations.
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
1helpful
2answers
User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Top Sander Tools & Hardware - Others Experts
vince
Ngoro
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
