Question about Golf
2009 Yamaha model YDRE electric golf cart. I have no brakes need help
SOURCE:
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
I965Mstang
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
I have a 2008 Yamaha YDRE electric golf cart, I replaced the solenoid. I have checked the key switch, the f/r switch and the toggle switch. I only have a positive reading on one side of the solenoid.
Only the battery side of the solenoid will be live until it receives an energising supply from the control circuitry and closes. In the energised and closed condition both sides of the solenoid will be live.
If an energising supply is present at the solenoid coil the solenoid could be faulty. If the energising supply is absent the control circuitry is at fault. Tracing the fault could be made easier by referring to a wiring diagram.
Oct 14, 2016 | Golf
Should the solenoid have increasing voltage across the main terminals, 9.0vdc to 30vdc. Master switch in tow, key switch off.
My answer is I don't know regarding golf carts but generally a designer would arrange for a solenoid to be actuated by as constant a voltage as possible, especially if it is to be engaged for long periods. That is the only method to ensure consistent operation without danger of overheating. This is assuming the available voltage energises the soleniod.
I would expect the voltage across the main terminals would also be expected to be fairly constant so a predictable consistent performance can be provided over a long life.
You really need to consult a repair manual/wiring diagram. As a complete uninitiated golf cart layman I would expect the main solenoid switch to be switching the battery voltage which would then supply the speed and direction control board. I could be worng though!
May 02, 2016 | Cars & Trucks
Where is the fuse for the headlights located on a 2009 Yamaha electric golf cart?
Go on BING images. Put in Yamaha Golf Cart diagram, and all sorts of info pops up.
Nov 15, 2014 | Motorcycles
Thanks,
Bob
Jan 05, 2009 | 1995 Volkswagen Golf
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
