Washing Machines Logo
Lonnie Parker Posted on May 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 400 washer fills but won't run - Kenmore Washing Machines
Rich Brown
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on May 13, 2019
Rich Brown
Expert
Level 2:
Scholar:
Answers
106
Questions
0
Helped
70948
Points
291
If the washer agitates, but does not spin and empty, it is most likely the switch that is activated by closing the lid. Those Kenmores from that time had a problem with the bracket cracking on that switch and then it would come loose and could not be activated. If it will not agitate, spin or empty, it is most likely the clutch, which kind of looks like a hockey puck with six holes in it. If you’re handy at all it is about a $20 part, and about 1/2 hour of work.
dadjr94
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 12, 2019
dadjr94
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
3689
Points
26
This is usually a sign that the lid switch/lock is not working and needs to be replaced.
5 Related Answers
Anonymous
  • Posted on Apr 14, 2009
SOURCE: doesnt fill with water
i got problem e 31
davidpsr
David Mcintosh
  • 222 Answers
  • Posted on Aug 21, 2009
SOURCE: Kenmore 400 washer on warm cycle begins to fill
When the water turns cold, check the other hot water outlets in the house. Possibly the water heater is simply running out of hot water.
If that's not it, I'd have the repairman replace the water valve and while he's got the hoses off, check to be sure the filter screens are not stopped up. There's really not much to the water temp control so there's not much else I can think of that might cause this problem.
First Service
  • 181 Answers
  • Posted on Aug 28, 2009
SOURCE: my kenmore 400 washer fills but nothing else
Lid switch is still most likely the problem. Are you able to unplug washer from wall and check the wire connected to the switch.
Anonymous
  • 572 Answers
  • Posted on Feb 06, 2010
SOURCE: my 400 series kenmore washer overflows when filled
check the preassure hose
Testimonial: "Fixya is so good, most problems can be solved DIY"
Anonymous
  • 207 Answers
  • Posted on Aug 20, 2011
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
My Kenmore 400 washer won't fill w/water. I can fill by hand n it washes fine!?!
It sounds like the water vale is gone bad. The valve or some call it a switch is what lets the hot or cold water into the washer Good Luck Mike L.
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
1helpful
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Its a 400 series washer actually, and it will only spin very small amounts of clothes. It won't even spin a single sheet by itself??
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
2helpful
My kenmore 400 washer fills but nothing else
Alexander
vince
