SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only. Make sure is is just "plain" no "scented" or "complete" or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!)
2. Use Jet Dry in the dispenser (set it to a 2-3 opening)
3. Make sure water is at least 120 degrees
4. Only run dishwasher on "normal" setting. All others just run it longer, hence causing more water stains.
5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes)
6. Do not wash sponges in dishwasher.
Acid Wash:
The repairman just gave my washer an Acid Wash today.
It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19.
I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance:
Glass Magic:
Buy a box of Glass Magic (near the Cascade) Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again.
White Vinegar:
You can run an empty dishwasher with white vinegar once a month. Fill a bowl with 2 cups vinegar and place on bottom rack. Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working. Good luck.
SOURCE: Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
There
are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in
detail....
Dishwasher Repair Problem Detergent
Cup does not Open
heatman101
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Daniel
