Hello Hugh, as I prove that its 4 HDMI ports, do not work ?, I try with another cable ?, the HDMI image source, with which I tested the four inputs, is the same?
Your HDMI image source, does it work?
It would be good to check the above indicated mind
Comment the results
Greetings Franco Dosil
Hola Hugh, como probo que sus 4 puertos HDMI, no funcionan?, probo con otro cable?, la fuente de imagen HDMI, con la que probo las cuatro entradas, es la misma?
Su fuente de imagen HDMI, funciona?
Seria bueno que compruebe lo indicado anterior mente
Comente los resultados
Saludos Franco Dosil
SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
SOURCE: PS3 HDMI - Sony Bravi KDL-40V2000 Problem
try this
